IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5641 Views
  • 14 replies
Hi,We are running CCM 4.1(3).During in the night i.e., 00:00 hrs to morning 6:00am we forward the Hunt list (90) number to Security personal (911). But call forwarding is not happening.After logout the Extension 90, forwarding the calls to 911, still...
rajupawar by Level 1
  • 1022 Views
  • 3 replies
Hi. I have two dial peers conflicting by the looks of it. Dial-peer 53 works fine.!dial-peer voice 53 pots description ** Outgoing national landline / mobiles ** destination-pattern 90.......... port 0/1/0 forward-digits 11 no sip-register!A colleagu...
davieshuw by Level 1
  • 1119 Views
  • 17 replies
Hi, hope you can help, have installed a UK numbering plan,Using route filters, partitions, route patterns (9.@ & predot) & call searching spaces etcthe problem is that I need to strip off the leading digit from area codes & mobiles at the call manage...
I have a remote VG248 issue.I have two ports going to one analog phone (Dual extensions on the phone)Port 45 -- Shows Link down (Ext 1009)Port 46 - Ext 1010when i go into port 45 it shows Call Maager Link downThe event logs show the following--- Port...
I don't get how an FXO port connected to an FXS port can distinguish the DNIS. Shouldn't the FXS port just apply ringing voltage to the FXO port without any DNIS passing?Here is the scenario:VoIPphone------(gateway)FXS----FXO(PBX)----phoneVoIP phone...
guys i m trying to install CCM 6 on VMware 6.....now i boot the dvd and everythijg is done but at the end it says cant get to th edefault gateway (detect) guys i m using bridg connection t my physial NIC......now i have given ip adress of CCM 192.16...
