IP Telephony and Phones
Labels
Helloin the upgrade documentation for Cisco Callmanager I found a Note that if I want to upgrade to CCM 4.2(3) from CCM 3.3 I need the 4.2(3) software kit. But I only have a software kit including CCM 4.2(1) and a webdownload with the Cisco Unified C...
telefonie by Contributor
  • 194 Views
  • 1 replies
I have 3 users that all need to manage 5 Mail boxes (for a call centre)Does anyone have a good way of doing this? users only have 1 line (but need to be alerted about a voicemail for each of the 5 mailboxes and they need to be able to log into each m...
Do I need to add on the switch/port that connect the Call Manager the command:auto qos voip trustI know that the command is used to connect the interface to a trusted switch or router. But can it be done on my publisher and subs. server?
Resolved! fast dial in ccme
we have a 3800 router and we are working on ccme . i want to add some numbers for fast dial ..i mean if i want to call 12345678 thn i will assaign this number to 45 and whoever will press this 45 it should directly dial this number. thx for your cons...
