Graceful H323 isdn shutdown
Hello,Is anyone aware of a way to gracefully shutdown a PRI for a h323 GW. I want to perserve active calls but prevent new calls from connecting.Thanks,
I am receiving alerts for CuMixer in RTMT and core dump file is found. When analyzed core dump, I got "Program terminated with signal 6. Aborted" Backtrace : Cucm. CUC version: 11.0.1.22900-14 .Any help appreciated
I'm wondering if it's possible to find how many calls are being dialed to a number that's being translated to another number? I've read some info in the CDR documation that summarized the answer best best with "When you add calling and called party...
Hello everyone, Being new to the UC world in general, I'm trying to get familiar with CUCM functionalities, let's say i'm OK doing most of the things on it just by practicing and searching when i get stuck in something In one of our previous proj...
Hello, i have a issue with Cisco Jabber Call, it not able to make calls as it is giving ring tone but calls are not getting connected.
Hello, when I add a new IP phone, extension, profile...etc I go through end user association or setting end user owner, why and what for we assign end user in multiple steps? we assign owner end user per device, we associate the extension with ...
Hello, I have 2 CUCM Nodes 1 Pub & 1 Sub I configured extension mobility and users login through extension mobility normally in the two sites Now When I add new ldap user and synced well, He can only login in The pub site and get an error 201 when he...
We are running Cisco Unified CM Administration System version: 11.5.1.12900-21. This is my first go at anything Cisco IP, so excuse my ignorance. We are able to call outbound, but when we call inbound, our SIP provider receives a 404 not found and ...
We are facing problem with ISD calling, hen someone dials the ISD number it hit on VGW able to hear rings but then call drop..even if the dialing number is any call center number then also we hear 7-8 dialing tone & then call dropCUCM 11.5Cisco4321
HiI have a cucm and a sip trunk. My outgoing calls are ok. But I cannot establish incoming calls. I want to translate my incoming calls to an extension(DID is needed). here are the configurations I set in the sip trunk:- Media Termination point is e...
While performing DRill test we observed that while transtions from Primary to subscriber was smooth, all phones registered to the subscriber without any issue but we are not able to receive incomning PSTN calls outgoing is working fine. I have checke...
We have cucm 8.5 in cluster Not not access the device default configuration in subscriber, showing Loading, i waited for 30 min, But i able to access the device default configuration in publisher.Publisher in Site A and subscriber in Site B, We have...
Hi, My client has migrated from the legacy key system to Cisco CUCME. He is used to seeing the red lights on the phone indicating the busy FXO lines. Hes asking for similar notification in Cisco CME. Is there any way to achieve this? I was thinking o...
I have a Unity Connection 11,5 SIP integrated to CUCM11.5. I have a AA set to call external number. When I use the AA the call hits the gateway, rings, then drops when answered. CUCM is sip to PSTN ANy IdwaUnity Conenction, IP Telephony
Hi All, we have configuration in ASR CUBE voice class sip-profiles 1100 request INVITE sip-header SIP-Req-URI copy "sip:(.*)@" u11 request INVITE sip-header To modify "sip:.*@" "sip:\u11@" dial-peer voice 11010010 voip description eCUSP-PSTN dial-pe...
Subject | Author | Posted |
02-06-2023 10:54 AM | ||
02-01-2023 09:39 PM | ||
01-25-2023 05:07 AM | ||
01-24-2023 11:30 AM | ||
01-19-2023 08:07 AM |
User | Count |
10 | |
8 | |
4 | |
4 | |
2 |
