IP Telephony and Phones
Labels
Hello, we have several sites that are running CME 3.2 with 12.3(11)T11 code with no problems. However, at one small site the 2811 router is also running IPSEC over two T1's and we've had to source the VPN tunnel from a loopback to get load-balancing ...
Hi All, Is that possible to assign multiple user to same IP phone with defferent extension in CME? when I added new user in CUE GUI and want to associate the phone to that user, my desired phone has not been shown on the list. how come I add new user...
Hi,i have a 2801 with a vic2-2bri and 4fxs voice ports.Also the ccm is 5.0(x) and the gateway is configured as MGCP (I just hate MGCP for these simple implementation but i found it configured and i didn't want to change it!!Otherwise i would use H323...
dwtcp by Level 1
  • 282 Views
  • 1 replies
Unity Administration pages are not opening from few days and we checked the server to have a look and all services seemed to be running when we noticed that in the system tray was an icon that prompted me to "Start Unity".Voicemail is functioning cor...
Hi! I was looking at the following DST document:http://www.cisco.com/en/US/partner/tech/tk648/tk362/technologies_tech_note09186a00807ca437.shtmlIn particular I was looking for the update on Cisco Call Manager Express (with UNITY express , i.e. NM-CUE...
I have reconfigured the service variables on a CME system to change the times the display is active.This works fine however when the display turns off overnight as expected there is no way to override and get the screen back should you need it to see...
HI,I keep getting the following application event in event viewer.Event Type: InformationEvent Source: MSSQLSERVEREvent Category: (2)Event ID: 17052Date: 22/02/2007Time: 22:38:39User: SGPUBLISHER\AdministratorComputer: SGPUBLISHERDescription:Error...
davidme by Level 1
  • 373 Views
  • 1 replies
Hi People. i'm seeing a strange problem. a user picks up the phone...makes or receives a call. hangs up...but the phone stays connected....any ideas what i should look for? h323 gateways...CM 4.1never seen this problem before.
Unanswered Topics
