IP Telephony and Phones
Labels
IT
We have SG200 Series Switches and we are purchasing Spectralink IP-Detect base stationsRequirements are PTv2  mulitpackets must be on the same switched network segment. and must allow mulitcast traffic to and from all the base stations.Can this be co...
I have a 7965 phone that has registered to a Cisco 3945 in SRST mode.  It's the only phone out of 120 that has done so.  I'd like to reset the phone in the gateway. Does anyone know the command/procedure for resetting the phone from the gateway?  Not...
sbackus by Level 1
  • 7601 Views
  • 12 replies
Hi community,I'm testing CUBE SIPREC feature. The scenario is:A--> CUBE -->B          |          |----> SIPREC third-party recorder (Rec).When I make a call A->B, Rec receives two initial requests (INVITEs) rather than one, but with the metadata in o...
Hi,I'm tryng to accomplish a Sip trunk between two CME version 15.1(3)T3. From CME2 to CME1 worked but from CME1 to CME2 didn't worked, after the phone is dialed a busy tone is received and I got a Sip message SIP/2.0 403 Forbidden.                  ...
