IP Telephony and Phones
Personalize banner_3
Labels
Hi Everyone, I am trying cisco softphone it always show Cisco IP Communicator always show --------- saying Configuring IPNeed to confirm for IP communicator to work we need to open port 6970 also?SEcond thing we need to configure the call manager wit...
mahesh18 by Level 7
  • 3959 Views
  • 4 replies
 Hi Everyone, We implemented Cisco VOIP recently.On cisco switces we have no qos configured.When we make a call to our head office we notice Jitter.Should we enable auto qos on cisco switches?RegardsMAhesh
mahesh18 by Level 7
  • 580 Views
  • 4 replies
Resolved! CME to CME
This is really driving me nuts. I am not an expert with Cisco IP Telephony.I have two sites connected via VPN (Cyberoam Firewalls) and there is communication between two sites. (ping is working)But the IP Phones can not call each other, Internal is w...
Hi, A client setup was working fine before on the same configuration. The issue on the SIP trunk and came a week ago. In Saudia Arabia there are different telecom companies like Zain, Mobily and STC. This issue is only on the STC network when dialing...
Please clarify the following questions/assumptions:1. For PRI trunk, the VoIP gateway will be having physical ports which will be the end points which in turn will be having the channels.  On the other hand, SIP trunk is the logical trunk that is con...
prasanna.k1 by Community Member
  • 2427 Views
  • 5 replies
I have to propose a solution where I have a 5515x firewall with 6 GE interfaces. I need to make 4 physically separated port DMZ on this firewall. Each DMZ will be completely isolated from the other DMZ.So this means out of the 6 ports available, 1 po...
khan300 by Level 4
  • 527 Views
  • 1 replies
I have a customer school district that implemented CUCM last summer with most of the teachers getting the 7841 phones.  This is the first district that has used this phone in any large number. Since last November time frame they have been telling me ...
