IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6338 Views
  • 14 replies
Hi all, Good day.I just wanted to know of on my CUCM Admin web page, on PHONE NTP REFERENCE, if adding or deleting NTP's does make my CUCM to re-host my active licensed files.Because I changed the NTP server on the CLI call manager, (delete it and ad...
OK, so we are having CUCM 9.x and 2951 router with SIP trunk to PSTN. Router is set as h323 gateway for CUCM... Pretty simple configuration, nothing fancy, and everything is working as it should, but one thing.After we are call someone outside who is...
Resolved! VGA224 SRST
Hello all,I have registered the VG224 to the call manager using MGCP. There are couple of analog phones which is configured in the FXS ports. During WAN outage I want this to be registed to my gateway which will be on fall-back state. I have configur...
Hi everyoneI have installed 2 licenses (Advanced and Enhanced) on my CUCM 9 but only one is used for my instance. I need delete one license (Advanced) for my CUCM uses the enhanced license.How is that possible?Regards.
