Hi team,I have a CUCM 8.5 here. So, I want to create a route group, but I don´t have available devices in call routing> route/hunt > .route group. Can you help me please? the print file was attached.thanks.
When I backup our Unity I receive this error on the messages and only get to 88 percent on the backup.Thanks,Component : MESSAGESTime Completed: 2012-01-13-10-08-54Result Code : 1Result String : ERROR Component : MESSAGESTime Completed: 2012-01-13-10...
Hi In Cisco Unity Connection 8, what is the difference between Intrasite and Intersite Networking?Also, can CUC 7.x and 8.x co-exist?
CSCsd54344 Bug "DSP: Persistent echo heard on c5510 DSPs with 4.4.13 DSPware or higher", was identified on Cisco 2801/2811/2821/2851/3825/3845 with PVDM2 DSP. We have a 2821, IOS version 12.4(20)T2 with DSP Type C5510 and, DSPWARE Version 23.8.0 with...
Hello, I have a question concerning VWICs and 3945e Voice Routers.Our customer uses 3945e Voice Routers, and we want to add VWICs in it. Now, part of the box already uses VWIC3-modules, but we still have some VWIC2-modules that we could use.Can we co...
All,I have approximately 16 remote sites, each with their own local PRI (some with multiple PRIs) - we are just starting to receive complaints of crackling on the IP phones when initiating outbound calls to the PSTN. Internal calls are fine as well a...
Have a rls 8.5 cluster, with some phones configured to call forward no answer on busy/off etc externally to a pager. The actual call forward works as designed, but callers do not hear all of the pager beeps. Seems that there may be a timer of some so...
Hi CUCM Team,We recently discovered a defect in the BIOS on the UCS C-series servers :CSCtw68712 UCS C-series bios fix for VMware ESx intel interrupt remapping issue Symptoms on CUCM server :missing keepalives (SDLLinkOOS) phone unregister high I...
We recieved a cisco CMBE server with all its softwares on release 8.6 but after downloading the license offered, we found out that it was of release 8.0.How do we resolve this issue since the release 8.0 license is not updating the call manager and ...
hi guyswe have unity unified messaging on external Exchange 2010. we are facing with MWI, if a caller who is not a subscriber of the system leaves a message, MWI works. But if a message is left by the caller who is a subscriber of the unity system, M...
Hi all,I Have a LDAP server with the attribute of telephone number named "CiscoTelehpneNumber" instead of "TelephoneNumber", there is a way to map that fiel in order to be taken from the LDAP server to CISCO User management.Here is a Image,For exampl...
Hello all,I need to Know i someone can tell me how to limit ring duration on a CUCM phone. I will like that when a calling party make an unanswered call to à called party, the calling party phone stops ring after maybe 5 rings!I will appreciate if so...
Hello AllI would need an advise on the following;I have a remote IP Phone and I am required to create a passcode for it to be able to make phone calls. The IP Phone is registering to a Router offshore setup as a Call Manager Express: Is there any way...
Greetings,I would like to clean up my CUOM install and remove the cluster that it initially discovered before I rememberd to change the Enterprise Parameter in CUCM from "StandAloneCluster". Now I have two clusters one with my newly named cluster and...
Hi, I was wondering if someone ould help me with a few things?Im learning about queueing, marking, etc.If i have 3 routers in a chain, and the two outer routers are implementing dscp marking on ingress traffic using class maps and policy maps, (I ass...
| Subject | Author | Posted |
| 12-31-2025 01:52 PM | ||
| 12-10-2025 11:24 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM |
