IP Telephony and Phones
Labels
Can anyone confirm that you can install 7.X on a UCS C-Series.  I have a client that is running 4.1.3 and we are about to do an upgrade on new hardware.  We will want to get to 8.x in the end but You have to go to 6/7 in order to upgrade to 8.  The i...
rweber by Beginner
  • 855 Views
  • 6 replies
Hi All, I have 2 VG30D's that are not accessable via the web interface so tried the craft RS232 port but still can't get any access - tested the cable - all OK. The guide says use the stubb RJ45 cross-over cable but the port is a old style 9Pin RS232...
Resolved! CCM backup warning
CCM 4.3, IPCC 4.1.1. The pub is backing up the cluster it says backup for CCM and IPCC successful but also a warning, any ideas what it is or is this something I should be worried about.''02:02:11 AM]   Copying /STI/Backup/CRS/clusters.properties to ...
Hi,I want to do a DMA from CCM 4.0(2A) to 6.1(1A).The version 6.1(1A) will be running on a brand new server.I ran the CallManager Upgrade Assistant file CCMUpgdAsstInstall.4-3-13.exe. And everything was OK exept the memory.My old server is MCS-7835i-...
lpaquin by Beginner
  • 345 Views
  • 2 replies
HiI am looking into upgrading 2 presence clusters from ver 6 to 8, prior to upgrading to callmanager 8.The Presence 8 release notes say you have to do an interim upgrade to Presence 7 then 8, but the cisco.com/upgrade has a product 'CUP6-8.0-U-K9=', ...
Hi,I have two cisco 2800 routers, one of the fxo ports on the first router is connected to the PBX, on the other side I have similar router with fxs interface connected to analog telephone, when calling the fxs port the caller id is not displayed on ...
