IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6058 Views
  • 14 replies
Hello,I think I have a slight issue with the way my cluster is set up.I have one publisher and one subscriber.They are both running 7.1.5.32020-1.When our partner came in to do the initial build of the CUCM in their documentation it had said that all...
latintrpt by Level 1
  • 2807 Views
  • 15 replies
I'm trying to enable liverecord and I get the error "current version of IOS not supported" I have upgraded the IOS and get the same error. I am trying to configure this feature through the CCA tool. What version of IOS for the UC520 do I require to e...
Voice Gaeway, suddenly E1 PRI controller E10/0/0 and associated serial interface channel flaps, going down and up several times in a minutes.Once Voice Gateway is restarted it is back to normal.Getting following logs during serial flap.480: 1153639: ...
