Hi,I notice that each time I do an upgrade with CUCM or Cisco Unity Connection in VMWare, I double My VM disk. Is there a way to delete the inactive partition?Is it possible with "root' account?thanks a lotRahaman
Hi, help needed,Having this seriuos problem, telco said everything is ok form their point of view.This is my config and my statusnetwork-clock-participate wic 0network-clock-select 1 E1 0/0/0isdn switch-type primary-net5controller E1 0/0/0 framing NO...
how do i configure strip pre dot digits on a call manager express 7.1?or, i have to configure a dial plan , for international calls is 00T , but they havo to dial 0 to go out so it would be 000T, how can i gave ride of the first digit?ThanksCesar
I have a Cisco IOS voice gateway with two QSIG connections to an ISDX PBX using a couple of Westell IQ3000 QSIG/DPNSS convertors. One of the Westell convertors recently died and we have attempted to replace it with the Cisco VG30D, which is the Weste...
Everyone,I have a CUCM 8.0(3) cluster with PhoneVPN enabled. The ASA 5510 hosting the AnyConnect VPN service is running 8.3(2). The 7975G phone using the VPN client is running 9.0(3) software.FYI, the 7975G phone connects up just fine to the AnyConn...
Dear allNow , I meet an question, Our Customer has an ipt network and they tell us the ip phone need to apply partition and css policy in each phone , Does any can help me , Has any one can tell me best method to be possible to let me fast complete t...
We have an issue regarding the call display on the 7965/7942 phones. Here it goes....When we receive a call on either a 7965 with multiple lines configured, and the call is placed on hold, we see a call display with the incoming number flashing o...
Greetings to all! I have tried to get this issue straightened out for a few weeks now but just can't seem to crack the code. I have a uc540 that is connected to my DSL modem/router combo. I have DMZ'ed the uc540 and disabled SIP ALG on my modem/ro...
Dear is there any way to contact the CME so that it can generate calls to the Asterisk AMI style? I think that is an application and this is communicated via tcp / ip with CME to generate calls?
Can anyone help me? I can not find List.xml on my tftp server and also I don't understand how can I edit tftp files in CUCM 5.1 it gives me only one option to upload file.thank you in advance
Hi Folks, Excuse me for the simple question as I think I know the answer but I want to be SURE before going forth with it. Recently we did an installation of Call Manager 7 for a customer and they originally chose not to integrate it with their ...
hello, what steps do i have to follow to configure 2 VWIC2-1MFT-T1/E1 in a 2920, i found lot of information for other platforms, but not for that oneThanks a lotCesar
I have a VWIC card that I'm trying to bring up on a Voice PRI circuit. I am off-site and don't have physical access to the card. I've tried new patch cables and reseated the card but I can never get the Layer Status beyond "Deactivated". sh diag d...
Hello guys I have uploaded logos for ip phone 7945, 7965 and 7975 but the logos are not available from the settings menu.I have checked the resolution of the logos, and the directory and all seems to be ok.Has any one faced this issue?Thank you for y...
I plan to use "mobile connect" feature for big UC customer.But, "mobile connect" is able to use only T1-PRI, written by CUCM SRND.I plan to use BRI at a lot of branches, and tested no problems.Why unsupport of BRI? What's problems? What's going to ha...
Subject | Author | Posted |
03-18-2025 05:41 AM | ||
03-16-2025 03:42 AM | ||
03-14-2025 01:29 AM | ||
03-12-2025 07:27 AM | ||
03-06-2025 12:59 PM |
User | Count |
6 | |
3 | |
3 | |
1 | |
1 |
