IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6067 Views
  • 14 replies
Hi     I am using Cisco Unified Communication Mnager 7.0 and i have uploaded Arabic Locale on it and it was successfully uploaded     but when i change the user locale under device---Phone--select the phone and change the user locale to Arabic but th...
Hi All, I have a small remote site that has a 2851 runnning CME 7 and wish to get the phones to register to a CUCM (v7.1)in London. Currently the PSTN connections are 5 x FXO ports that have PLAR OPX configured to reception x100. The CME will be regi...
stowellp by Level 1
  • 1107 Views
  • 2 replies
Hi, In our "Cisco Unified CM Administration System version: 7.0.1.11000-2" installation, I have a CISCO IP Phone 7940 series with the number 1595. In the "Multiple Call/Call Waiting Settings on Device SEP0014691B5534", I have configured the phone wit...
Does anyone has any doco / demo on how to setup mobility server 1.1?? I have installed the server as per installation guide. But i just don't understand how to configure the server... e.g. it has different types of CTI ports and i don't understand ...
huntlee by Level 1
  • 285 Views
  • 2 replies
I have a copy of this software and need to know a couple of thingstwo things I need to know 1) can you get Unified Mobile Communicator for Symbian OS Phones or is it only for blackberry2) do I need Unified Mobility Advantage Proxy Server and where ca...
Hi, I have a CISCO IP Phone 7960 with a 7914 Expansion Module, so that the secretary can monitor and overview the persons that she has configured on the 7914 Expansion Module. The only downside is that when a person calls one of the numbers that she ...
Hello,I have VMWare server 1.0.8 installed on DL 320-g5. I have two virtual machines, CUCM 6.1.1 which works fine and CUPS 7 which doesn't work so fine. CUPS has periods when seems to be working fine, and then crashes (??) without no apparent reason ...
Hi,i know that is better specify an IP address for all member of CUCM cluster. The procedure deals with going to CUCM servers, change the name to IP and, finally, change the URL's in "enterprise parameters" to allow phones use IP too. My question is ...
Can some one confirm exactly what licences I need to run CUPS with CM and CUIPCIts looks like I neednode license to run the software on the server  –license to run personal communicator – DLUs to run CUPCIn addition for every user you activate in CUP...
