IP Telephony and Phones
Labels
Resolved! CCM cli usage
Hello all,I have runned the following command:utils dbreplication status allAnd receive the following message:Output is in file cm/trace/dbl/sdi/ReplicationStatus.155220.out How can I see this file? I have tried with RTMT with no success.Many thanks
mcecilia by Level 1
  • 252 Views
  • 1 replies
Dear All, We are planning to implement IP phones in our network(attached the switch-diagram). Right now we have the following switches configured as our Access layer switches.all are cisco 2950 switches but in some switches there is a slight change i...
Shibu1978 by Level 1
  • 612 Views
  • 3 replies
Hello,I'm running CCME 7.1I want to install a 7965 + 7916.So I add the ephone like that :ephone 89 mac-address 0024.14B4.C408 type 7965 addon 1 7916-24 button 4:64 12:63!No problem with button 4 (on the phone 7965)But for button 12, I don't have th...
dufour001 by Level 1
  • 266 Views
  • 0 replies
We are trying to use some T.38 fax software (non-Cisco) from behind an 800-series router (877). Inbound faxes work fine but outbound ones fail every time, the software claims that the remote machine never responds.Is there any special configuration n...
customer having Call Manager for thier IPT services. He want to use ATA for fax, need to integrate with Call manager (CUCM6-BE).Please suggest me license option , which is required here. Here i m finding 3 option for license (SW-CCM-UL-ANA, SW-SMH-UL...
HiI have a 2811 CCME. I've just done a reboot of it (after doing a wr) and its come back up fine.However - all of the handsets have lost their custom rings.When I try to browse the rings the handsets say they cannot find the ring list.I've checked fl...
davieshuw by Level 1
  • 662 Views
  • 2 replies
