IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6067 Views
  • 14 replies
I have two users that want their phone calls sent to each other. If some one calls Ext: 8001 and the person is not there they want the call to go to Ext: 8003. If some one calls Ext: 8003 and the person is not there they want the call to go to Ext: 8...
Mojo1 by Level 1
  • 905 Views
  • 8 replies
I am operating Cisco Call Manager v7. It is purely the IP system, with no PSTN lines.We do have connections with other Call Managers in other countries, for which I use Hunt Groups to route the calls.I am trying to see if its possible to do 2 things...
davidbeel by Level 1
  • 464 Views
  • 4 replies
I have a network with a UC500 connected to a 3750 switch going through an ASA.The ISP is currently having problem, so the site will be offline overnight.I have no experience with VoIP, so will this be a problem in the morning? When the WAN comes bac...
Get the following error while trying to upgrade to 7.1.2 Downloaded from Cisco's web site, and am doing local install. It detects the file, then hit next and get "The version number inside the selected upgrade does not match the filename"thanks
