CDRs with wrong time CCM6.0
hi, the system time is right, but the CDRs are comming to the sFTP server, do you know whats going on?
I have a Call Manager Cluster (4.2.3SR3a) directly connected to the UK PSTN via H.323 trunks.Incoming call to an IP phone with CLI permitted. Called phone has CFWD ALL set to a users mobile phone. The users mobile phone displays the incoming CLI rat...
Looking for the latest version of QCT. I have found a version 3.01 from Nov 2006. Is there something newer or is there a newer tool for configuring Call Manager Express (besides the UC500 tool which is limited).Thanks.
Hello everyone,I've got a UC500 installation with two 7941 IP Phones and for some reason, there is no call history on the IP Phones. As such, the customer is unable to view his missed calls!Any idea what the problem might be ? I've also connected an...
I have a customer that uses the 911 service fairly often and when they are on the line for more than a 4-6 minutes, the calls terminate unexpectedly. The customer is using CM 3.3 with an MGCP controlled CAS T1 in the gateway. Any troubleshooting tips...
Hello,Does anybody know whether it is possible to visualize the outlook calendar of an Extension Mobility user on the phone where (s)he is logged into ?Perhaps via an XML service or possibly a third party ?Thanks for your feedback.Dirk
Installing a new PRI at new location. Can I take a 2611 non voice sw, with a plain wic (not vwic), and use it to verify whether all 24 channels are up or not?
Hello,I have a question regarding TAPS. How do I define what DN's are going to be given to the phone when they dial the TAPS number. Is the number given out with what is defined in auto registration or is it defined in your BAT file with Dummy MACS...
I have just set conference and transcoding in CME but I can not transfer call, even internal.sccp local GigabitEthernet0/1sccp ccm 10.10.10.1 identifier 1 version 4.0sccp!sccp ccm group 1 associate ccm 1 priority 1 associate profile 2 register CFB...
Hi all,We have many phones within our organisation that need their firmware re-flashing.Is there a way of doing this without sending the phone back to Cisco?Thanks,Jamie
Does anybody know if these scripts has been tested with CUCM 6.1.2 or older versions?Thanks,EA
I'm looking to deploy UC500 and use a SIP trunking provider for off-net inbound/outbound calls.I want to use G.729 on the SIP trunk, however I know that CUE only support G711. Is it possible to configure UC500 to transcode the G.729 SIP Trunk calls ...
Hello,How do i re image cisco unity express which has an express license to work with cisco call manager 4.2?
Hi there,I'm trying to insert phones using BAT. I created a template. Now I'm looking for the "Excle Sheet". Where I can find/download that BAT.xlt? Thanks.
Currently I have HP ProLiant DL320 G3 (Hardware type: MCS-7825-H1-IPC1) and call manager 4.1.3 is installed. I like to know if Unified communication manager 6.1.2 can be installed on that hardware platform. Also please do share with me if you have th...
Subject | Author | Posted |
01-25-2023 05:07 AM | ||
01-24-2023 11:30 AM | ||
01-19-2023 08:07 AM | ||
01-16-2023 05:26 PM | ||
01-16-2023 10:22 AM |
User | Count |
8 | |
7 | |
4 | |
4 | |
1 |
