IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5903 Views
  • 14 replies
We are on CM 4.1(3)sr7 with our voice on PRI and are still using PSTN for faxing. I am looking for someone who has ATA's working in a similar environment. Can you tell me what model you are using or recommend the model best for our version and purpos...
Hello,I have installed CCM 6.1 and configured some 7911. I configured EM and users can log/logout fine to those devices.then tried to put in work some 7936, the problem is I can't use EM with these device. I configured user profiles and logout profil...
Hi Guys,I am trying to do the backup using the tool BARS and is appear the following message:"The CCM DB on publisher 10.9.8.81 is not published. Please correct this invalid configuration by properly publishing the CCM DB on publisher before configur...
Hi all, just wondering if someone could review my translation the goal is to make outbound caller ID for local as a 10 digit number and LD as a 11 digit number... thoughts? main number being 8015555555 examplevoice translation-rule 1 rule 1 /^9/ /801...
rywalker by Level 1
  • 701 Views
  • 3 replies
I inherited a CME in London and just installed one here in the US. I have extension to extension call working, now I am trying to configure the US CME to be able to make regular calls through the London CME via our VPN. I am looking for an example co...
wplantier by Level 1
  • 1419 Views
  • 21 replies
Hi,Recently, I have encounter publisher outage and realised that the subscriber unable to access the corporate directory.Would like to know when the publisher is not in service, is it normal for the subscriber not able to access the corporate directo...
howct7231 by Level 1
  • 534 Views
  • 4 replies
Guys,Anyone know of a product that matches the Avaya softphone in that if a website contains phone numbers they are highlighted and you can double click on them and the softphone dials the number. Really nice feature, do we know if there is an enhanc...
bigcappa1 by Level 4
  • 321 Views
  • 3 replies
