IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6067 Views
  • 14 replies
Hi,Were having issues dialing the UK from or California office. We can dial all of our international sites except the UK. Below is a debug for the dial peer and q931 on the PRI. The number were calling is British Telecom as an example. Dial Stri...
If I understand this correctly when I enable DirSync then my CUCM publisher will pull data from AD, store it locally, and query against it when a DIRECTORIES search is done on a Cisco phone?There is also a setting in CUCM under CUCM ADMINISTRATION-->...
The company I work for uses Cisco IP Phone 7941 Series. When I call potental clients the phone rings but the call time counter on the screen doesnt start until someone picks up or an answering machine answers. Is this counter the call time counter? I...
Hyperion2 by Level 1
  • 559 Views
  • 1 replies
Hi experts,I have been dealing with an issue while trying to connect a Nortel BCM to a Cisco CCM, basically I was able to configure both of them but for some reason I am only able to have they working together with g.711alaw, if I try something diffe...
Hi, i have four VG248 with 1.3(2) version in the same site. The problem is the VG248 are reseting. For this i checked in the System Status the Up Time param. The fault is random.The logs are not show the reason for the reset.Pls see the attachment.
I have a user request to provide hold times on a DN. This is not a call center where we can use the Historical Reporting tool.This is just a simple DN and I need to report on hold times.Anyone know where this is buried in the CDR?
asafayan by Level 4
  • 252 Views
  • 1 replies
Hello,I have CCME 4.0(3) on routeur 2801 andI want to redirect the inbound calls from PSTN to four IP Phones. So when we call from the PSTN the 4 Ip Phones Ring.I know that it is possible with connection PLAR on voice port but it support only one eph...
microtel by Level 1
  • 606 Views
  • 7 replies
