IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5824 Views
  • 14 replies
Dear all,I add the following command on ccme but i can only made a conference call with three user at a time from my 7941 phone.telephony-service max-conferences 8 gain -6Any other config is required to make conference call with more than 3 users.Tha...
Hi,I am trying to configure a SIP account on my 2801 ISR Router using the CUBE functionality. I have tried all possible configuration combinations but it does not seem to register. The account works fine if I use a softphone such as X-Lite. My config...
I recently installed an Emergency Responder server. One issue I didn't realize is when I installed the Cisco OS, the windows NTP client didn't install. There are so many Cisco OS cd's, so I'm not sure which one to choose from that would have that c...
Specs indicate that the NM-CUE and NM-CUE-EC have the same 20GB hard drive. I was just wondering why is one 100 hours of storage and the other 300 hours of storage if both have the same hard drive capacity?If I wanted to upgrade my NM-CUE to provide ...
I have a user that just installed IP Communicator 2.12. It starts up okay but if he attempts to answer a call or place a call he gets a MS Visual C++ Runtime Library pop-up R6025 -pure virtual function call. What's this mean and how do I fix it?
k6lw by Level 4
  • 1680 Views
  • 1 replies
Just curious.Is it possible for a "lab" call manager (5.04) to use the production directory data (3.3.3 sr4) for the corporate directory access? If so how do I configure CCM 5 to do this. I just want to display the corporate directory, not perform an...
k6lw by Level 4
  • 251 Views
  • 2 replies
