IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6216 Views
  • 14 replies
I have a sip provider i'm trying to makes calls OUT to from a CUCM, via a CUBE...On outbound calls i'm getting this message in a trace -- the destination phone on the other side of hte PSTN rings once -- but that's it, and right after it rings the ca...
my 7985 iphone can not dial the pstn.but others is no problem.CCS and partion is ok! there is my debug:26 03:23:39.830: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0122 Bearer Capability i = 0x8890 Standard = CCITT ...
We have a router that is going to have varios connections. I need help understanding how to appropriatly setup the clocking.First, we have a single PRI coming in from Telco into a vwic-2mft1 (on port one - 0/0/0). I assume that it is this port that...
SBCdd7343 by Level 1
  • 289 Views
  • 3 replies
I'd like to use the BAT.XLT file to populate a MCCP VG224 gateway. The BAT.XLT file I have doesn't support this. We're running BAT 5.1(4R). Basically, the MAC address for each gateway port is 15 characters and BAT only allows 12. Is there a more ...
Resolved! German ISDN Voice
I have a 2821 router in Germany configured as a H323 gateway and is attached to an ISDN PRI line. The E1 PRI line is configured with primary-net5 ISDN switch type.The problem is that about 5 inbound calls from the German ISDN network arrive with one ...
jdsalminen by Level 1
  • 1670 Views
  • 20 replies
Unanswered Topics
