IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5891 Views
  • 14 replies
Hi I just want to know whether there are any possibilities to make an extension dial out to National/Mobile numbers and not to allow any incoming calls to that number ? Except for calling from other extensions ( within a site and from other sites).....
Hi,I have Cisco Call Manager running on a 2800 series router and have a Cisco ATA-186 (SCCP firmware) that I wish to use for a couple of faxes. I've tried adding the following lines to my configuration however whilst a fax answers an incoming call i...
Once the custom background image is working for the 7970 telephones, we wondered if it was possible to force a particular image across the enterprise. I've tried the "Background Deployment 1.0" product from VoIP Integration but like some others, it ...
bji by Level 1
  • 424 Views
  • 2 replies
Hi,When going to the OS Administration page through Callmanager Administration, I get a page that is empty and states:Directory Listing For /Filename Size Last ModifiedApache Tomcat/5.0This happens as well when going to https://ccm-ip-address/iptpl...
rtse by Level 4
  • 336 Views
  • 2 replies
Hi guys,i 'm installing ccm 5.1.2.1000-11.From sofware download page i got the cossispndent patch and burned it into a DVD but the call manager don't want it.(no valid options avaible).I tried via ftp but the same message occured.Any idea about what ...
CDR reports don't work. An error is showed in the screen when I execute a new report saying: "Data is not avalaible in the database" but I can export all cdr records and I can see al call detail so data is stored well in CDR database.Can anybody help...
Hi,We recently got (purchased) a new CCM with version 5.1, we are running out of some issues in the configuration and now we want to re-image the system and start the fresh configuration. However the CCM did not came with the OS re-image CD (normally...
rv_viji by Level 1
  • 275 Views
  • 1 replies
I have a CCM 4.X in my office and I?m having issue with the expansion module. The module (just 1) is attached to a CP-7960 Phone. When I try to configure speed dial numbers and Label on the expansion module, it accepts the numbers from the 7th button...
