IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5905 Views
  • 14 replies
The question is:  does the same make/model router support a different number of phones if it is configured as simply a CUCME device versus configured as as SRST fallback device? Different Cisco documents seem to give different supported numbers - ind...
Hello Pros, I need to run a test call which needs to least at least 8 hours.  It looks like my SBC is terminâting the call after about 60 minutes by seding a Bye message. In CUCM the Max Call Duration is set to 720 mins but the call gets disconnected...
