IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6164 Views
  • 14 replies
Hi Guys, I have to configure TEHO for a customer and I am trying to build out the route plan. The standard local route group will be used. So has a sample for the route plan: Anguilla Phone dial Bahamas Called number 91242XXXXXXX-> routes to baham...
rramlal by Level 1
  • 233 Views
  • 2 replies
Hi Guys, I need your help! I have set up a standalone CUC VM for a branch site. The intention is that if the WAN link is down, customers can call them and get the AA feature. So far I have set this up as follows: 1. SIP integration with cucm and cuc...
rramlal by Level 1
  • 198 Views
  • 2 replies
Campus Building has multiple fax machines in one room with 1 RJ11 wall jack on the wall in that class room.  Is it possible to install a 5 port rj11 splitter to wall jack to have 5 fax lines and how is it suppose to be connected to the VG224 section?...
I have my IPCommunicator programmed to forward to another number when not answered. My number is programmed to forward to another number if I don't pick up or am on another call. However, when I disconnect my PC my calls don't forward to that number,...
gerton510 by Level 1
  • 400 Views
  • 1 replies
