Resolved! Need Suggestion on CUBE Hardware for Lab
Hi Guys, I need a Router 2911 for Lab purpose under NFR. Wish to know if I can use it for CME, CUE (with additional module) and CUBE ?
Hi Guys! Would like to seek you help with this problem. I have a call manager 10.5 controlling singe circuit E1 via MGCP. This E1 Circuit has 3 DDI range with it. Let's say; 780 76XX 464 25XX 354 11XX I am implementing 4-digit DN scheme. My problem...
Hi We have CUCM 9.1 with 7945 and 9951 phones, I have uploaded new background imanges for these phone models, and users chan change the background image by user options succesfully. But I need to push same background image to every phone, no need to ...
Hello All, I am facing issue with FXO line connection on my cisco 2911 series router on which i am running CME. Issue: My FXO lines are not getting disconnected even after users at receiver end or user who dial disconnect the call. Lines getting...
So I am working with a customer who is trying to set up native call queuing. Everything looks ok and the calls come in but they don't seem to be able to be answered. When someone tried to pick up a call the phone stops ringing and it tries to conne...
Hi, I've seen posts similar to mine that were solved changing the name under ephone-template #; but my CME was configured using ephone templates and registering the phones under pools #. I've changed the name under the equivalent "voice register dn #...
Hi, I'm after a bit of clarity, is anyone able to provide me with any :) ? I'm trying to understand how the actual phone call flows after it's all been setup and brokered by CUCM. I've seen the classic picture showing internal calls where the CUCM ...
INBOUNDCall The following translations should be included on the voice gateway to ensure all inbound calls arrive at the destination with the correct Calling Line ID (i.e. include the PSTN access code of 0) to enable missed or received calls to be ...
In our current Hunt Group/Pilot (2000), we have it configured to Forward Hunt No Answer and Forward Hunt Busy to 3000. However, this isn't happening. Instead, it's going to the 2000 mailbox. In most cases, I would just put a greeting on 2000 and be d...
Hi I have spec the get current stay current for CUCM. However the part number that I see for CUC is a bit miss leading UNITYCN11-VUP-K9. Then I read that I would be able to migrate the license from CUC 7 to 11 by using COBRAS together with PLM to con...
Hello All, I sync'd up to the wrong Active Directory Server. I removed the old AD server in CUCM 11 and pointed it to the correct AD server and sync'd up. Now I have a dozen or so "Inactive LDAP Synchronized Users" and It's been about two days. I wou...
Where would one purchase extra rechargeable batteries for the 8831 wireless mics?Here is the info on the battery itself: E502248470mAh, 1.74wHP/N 4500044-00"
I am trying to find a replacement battery for the wireless mic's connected to an 8831 Conf Phone.The mic's part number ,I believe is 4500044-00. I do not know the part number of the battery
Hi, we have cucm , cuc 10.5 when I call the callhandler I heard the personal record during it I press an internal extension , but I hear " sorry we cant transfer to this number" I checked Allow Transfers to Numbers Not Associated with Users or Call ...
Subject | Author | Posted |
07-07-2025 06:07 AM | ||
07-06-2025 10:19 PM | ||
07-03-2025 12:55 PM | ||
07-02-2025 08:49 AM | ||
07-01-2025 09:51 PM |
User | Count |
2 | |
1 | |
1 | |
1 | |
1 |
