IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6166 Views
  • 14 replies
Resolved! CME doubt
hello all, am new to cme, i need to configure cme without seperate dhcp server. iis it good to configure with static ip heard cme can be configured in 2 way sccp and sip in which  case i should go for sip and sccp? is there any reference doc for my ...
Hi  I have a CUCM 10.5.2.10000-5 and a OpenLDAP in my OpenLDAP I have the user created and working, when I synchronize the CUCM with the OpenLDAP directory only synchronize a few user, and only one user with all parameters, if I review and compre the...
hi i config a pri GW ,the GW connect to CUCM use H323 when i call a pstn phone ,is all right but when i call the internal call from PSTN,i will receive next  signaling   Mar 17 11:17:10.848: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0F3A ...
bo liu by Level 4
  • 369 Views
  • 2 replies
I have an issue logging in cross cluster with 8961 phones. It works fine with 7945. With the 8961 phones the logout and corporate directory are missing.
hjs by Level 1
  • 216 Views
  • 1 replies
HI Guys, I have a problem in random call drops internal to external & vice versa CUCM ----H323---SIP-----ITSP follwing log appears in CUBE SIP: Internal Error (INVITE, invalid IE content): IEC=1.1.100.7.35.2 on callID -1 Please advice
Suchi by Level 1
  • 1078 Views
  • 1 replies
