IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5959 Views
  • 14 replies
Hello, We are running CUC 9.1.2.11900-12.  We have two servers.  What is being noticed is, when user attempts to access voicemail through IP phone, it appears as though unity is entering the caller input.  Users have reported messages being deleted, ...
Ayaz Khan by Level 1
  • 337 Views
  • 2 replies
Hi.   I've seen discussions on (via a search) for various ways to find unregistered devices and more importantly, the last date they registered) so you know if a (for example) IP Communicator client has been active and therefore a valid device to lea...
voip7372 by Level 4
  • 2200 Views
  • 4 replies
Resolved! one way audio
Greetings from New York.we operate a SIP switch and a remote gateway using dedicated satellite link. the network worked perfectly with crystal clear voice quality.a week ago and without doing any changes, just of a sudden, the user couldn't hear ring...
Resolved! SRST Question.
hi all, I have a GW configured with srst I have to migrate this GW to a different location, but in this new location, the Internet access will not be enabled yet, my question is, when I connect all connected, will this phone go to srst mode? or I hav...
Hello, my institution has callmanager 8. The problem is main business number is giving a busy signal when dialed. All other extensions are working fine. This started happening after a power outage. I am not very strong on troubleshooting the phone sy...
Hi there,I´ve a CUCM 10.5 and two gateway H323 working for different location. When the call in for GW1 from PSTN and user put caller on hold the music play ok.But when the call in from PSTN GW2 and user put caller on hold, they just listen tone on h...
ggl277808 by Level 1
  • 342 Views
  • 5 replies
Hi,we have a shared line which can take 6 calls simultaneously. Let's assume that we have 4 calls going at once on that shared line.A fifth person (who can make a call on that line but is currently idle) wants to barge into one of the existing 4 call...
louis0001 by Level 3
  • 570 Views
  • 3 replies
