I need your help in setting up/configuring the ATA 187 on gateway 3925 router for fax services.Thanks,Ali
I have a cluster with 4 subsbribers. The cluster is divided on 2 UCS plataforms.We have installed now a new C210 M2 at a remote site and installed on it 2 clusters of IPCC.Aditionally, we tried to install 1 Call manager subscriber.All the insllation ...
Hello UC People I have a question .. how long should CUCM 8.6 installation take "time"Thnx in advance
As a general rule, should transcoding be done close to the source or destination?Is there any link/documentation that I can reference?ThanksJames
7931phone is not registration cme router 2811
Hi all, hope you are finewell, here is my problemI got a CME connected with PBX, the pbx sip license is only 10 sip trunks, the CME has about 80 registered phone.There is a VIP cisco number that i need to make it reachable from the nortel pbx any tim...
Hi All,I have CUCM 8.0.3 configured with Extension Mobility. The issue I'm facing with: when user tries to log in, user asked for 'change PIN'. I have set PINs via BAT for all the users and that need to be used. How can I disable it?Thanks!Tibor
Is there a method to configure RP (Route pattern ) to block any calls outside working hours ?I am using CUCM 8.6
I have a question to pose to the netpros...I am soon upgrading from CM 4.1 to UCS C200M2 CUCM 8.6. I am wondering...... instead of pulling the PUB from the cluster to upgrade to 7.X using DMA then preforming a bridge upgrade to 8.X. would it be possi...
Hi,We've got a Unity express module version 8.5.1 running a AA script that was created trough the GUI.the aa script plays a welcome message, and a small meny to redirect calls to hunt groups.When we are out of business hours, the A...
I have a few questions I want to confirm:We have CCM 6.1(4) in our cluster that we will soon be upgraded to CCM 8.0(3a).First I want to install CCM 8.0(3a) into the inactive partition on all CCM servers without switching the version (or rebooting the...
Hi,I am new, I have to design a network with 8 port FXO, so I was wondering if the Cisco 2811 could support two VIC2-4FXO card?
Hello to all , I have a publisher, Subscriber recently added both have 7.1.5.30000-1 version. In the new building I have a Cisco 3925, what is happening is that when making a call from outside can not see who perform, does not display the caller ID
I have a scenario for a customer in Europe where they have 2 E1-PRIs, each PRI is configured to allow the first 10 channels to be only for inbound and remaining 20 channels to be inbound/outbound. If I send a call out on channel that is only allowed...
We are getting this error when trying to sync.2012-06-01 13:22:19,539 ERROR [DSLDAPSyncImpl(72515187-27b0-dc9e-01e8-5835e5f4c0d2)] ldapplugable.DSLDAPSyncImpl (DSLDAPSyncImpl.java:608) - LDAPSync(72515187-27b0-dc9e-01e8-5835e5f4c0d2)[Run] javax.namin...
Subject | Author | Posted |
06-19-2025 08:23 PM | ||
06-17-2025 07:43 AM | ||
06-17-2025 06:11 AM | ||
06-09-2025 09:11 AM | ||
06-05-2025 02:29 PM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
