IP Telephony and Phones
Labels
I am cutting over to fatter pipe for my SIP PSTN trunking services which will require a downtime.  During the downtime for the voice gateway (which will hopefully be very short!) I wouldlike to have users at site A make calls via the voice gateway at...
mmedwid by Level 3
  • 546 Views
  • 2 replies
Resolved! Background Images
Is there a way to modify the default background image on the IP phones? The blue fleck (I think that is what it is called) is always the default image on the phones, but I want my custom image to be the default. I thought if my image was the first im...
Resolved! MCS 7800 sizing
HelloI didn't find a calulation for MCS 7800 servers and the recommend amount of user for callmanager 8.6. Does anyone have a such table? My installation  have 200 users.RegardsPascal
plingg by Level 1
  • 920 Views
  • 3 replies
Hi All,My client wants to see the entire 10 digits number including the area code when fitching the corporate directory of the phone. Currently what we see is just the 5 digits extension. We have 3 clusters world wide, the CUCM DB is synched with the...
Every time I reboot my MCS7825I4-K9-CMD1, I get the error : "Detedtion error on Legacy mode : The hardware you are using is not supported for this product. Hardware-check results: HW type [Vendor-Product] NOT SUPPORTED"When select "Continue" the serv...
Resolved! CME - SNR Issue
HI I am trying to setup SNR on in my CME lad i have found the configuration on the www but the commands it wants me to use are mobilitysnr 1004 delay 5 timeout 15 cfwd-noan 1001neither mobility or snr are options under the ephone-dnI am using the ful...
