IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5649 Views
  • 14 replies
Greetings,I know that using route lists allows having redundancy when a first H323 gateway in the route list has all its local voice ports being busy. That works fine.I'd like to provide the same redundancy mechanism when all remote voice ports are b...
l.demanet by Level 1
  • 448 Views
  • 3 replies
Is there a place on cisco.com to check if a particular patch/rollup is considered stable in a Unified VM environment. In my case, the Exchange Server is separate from Unity, but I don't want to break anything or cause issues when applying patches to ...
The setup is like this:[PSTN]--T1 PRI--[CUCM MGCP G/W]--T1 PRI--[Mitel PBX]--[analog phones]The issue:A person has a phone number that they don't realize is long distance, so they dial 9 250 xxx-xxxx. If he does it on a Cisco IP phone, he gets a reco...
