IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6059 Views
  • 14 replies
Resolved! 2821 Voice Gateway
I need to add more DSP resources to my voicegateway. I currently have 1 PVDMII 32 with 2 16 channel dsp ( I am guessing on the motherboard). My question is can I just order another PVDMII 32 and add this to my mother board? Or do I need some type of ...
dvanzee by Level 2
  • 563 Views
  • 2 replies
Can I get answer why the line on unregistered phone is still active? In older version of CCM, line could not receive call when the phone is unregistered? What is the purpose new changed approach?
goranr by Level 1
  • 482 Views
  • 4 replies
Hi, I got problem, I have connection to two providers, there are connected to me by 3825 gateways with dsp, but they want different packetization (sample size) of g711 (one need 10ms-80bytes packets and another need 20ms-160bytes packets) but on CCM ...
Hello,Anyone ever connect thier ccm environment to a Telehealth system, typically used for hospitals. My question is the doc calls for an analog loop start line...to my knowledge this is an FXO port, but could FXS be loop start also?
hbarrera2 by Level 1
  • 255 Views
  • 1 replies
Hello guys, i would like to know if fax passthrough is supported with a SIP Trunk with "MTP is required" checked ? I had to check the "MTP is required", because of conferences with outside users that did not work and because of PSTN prompt not played...
jtoque by Level 1
  • 2085 Views
  • 3 replies
I am getting the following error every 15 minutes in the event viewer on my ipccx server. crs version: 5.0(1)_Build433thanks!Event Type: ErrorEvent Source: Cisco Desktop VoIP Monitor ServiceEvent Category: NoneEvent ID: 4Date: 11/6/2008Time: 9:42:...
jones2sr by Level 1
  • 483 Views
  • 1 replies
