IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5648 Views
  • 14 replies
Hi all,REcently i have tried to configure Supervisory disconnect under a BRI card (using the Voice-port creted virtuall) but the command is no longer listed like in the FXO configuration.SO if i don't have my CPTONE country listed and there is no su...
when i connect Cisco IPC to callmanager 4.1.3 sr3 i am getting a error Unable to initialize support for cisco emergency responder service. Please consult your system administrator.The Cisco ip communicator version is 2.1.3.0after geting the error al...
Hi everybody. Thanks in advance for your help.I am having problems with my router. The "csim start num" command does not work in it.I am attaching the output from that command:csim start 1584csim: called number = 1584, loop count = 1 ping count = 0cs...
Hi,I am planning to upgrade from Unity 4.2(1) to Unity 5 (Exchange 2007 support is needed). To make the least disruption to our production environment I will be building two separate Unity servers and installing Unity 5 on them.Both will be working a...
dknov by Level 3
  • 259 Views
  • 1 replies
Hi all,I want to ask about CDR raw files comparison between CCM 5.x and CCM 6.xIs there any difference between the CDR raw files of the two versions ? May be someone who has implemented both versions can show me what are the differences?For third par...
sr2290723 by Level 1
  • 437 Views
  • 4 replies
Hi,I have Unity 4.2 with UM setup and Exchange 2003.I have to edit a few Subscribers to reference different Exchange alias. SA GUI does not allow that, none of the Unity Depot tools seem to allow it and the only way I have seen doing it is to edit S...
dknov by Level 3
  • 362 Views
  • 2 replies
