IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6051 Views
  • 14 replies
Hi I have been asked by my company to set up a phone system after 2 days of playing with it. Suprisingly most of it is working but I don't seem to be able to get any outgoing or incoming calls. I have got closer with debugging but now seem to have hi...
Hi all,I have a question concerning a sort of "least cost routing"...I use the callmanager in version 4.2(3)sr3.There is a connection to our PSTN by a Cisco 2811 router which is configured to act as a MGCP gateway. We use a route pattern 0.! to let ...
bolz_icw_ by Level 1
  • 284 Views
  • 1 replies
I have about 15 different fax machines connected to a VG224 (various models). For some reason only the Brother 3800 models can not send (but they can receive). The VG224 is configured with MGCP and the PSTN gateway is running H323. I've tried settin...
Hi,Is there a good reference available on how to configure call transfer during voicemail prompt.What I'd like to do is if a call to an extension is unanswered and goes to VM, that the prompt says something like: "Press 1 to be transferred to my mobi...
I am looking at the Cisco supported hardware page and noticed the following server "HP DL320-G5 Server with Intel 3050 Xeon 2.13-GHz Processor" does not require a hardware RAID controller. Is this correct? Does 2000.4.5 or CUCM 6.x support softwa...
Hi experts,We received this notification from RTMT:Cisco At 10:21:14 on 02/09/2008 on node x.x.x.x.Service status is DOWN .The following service(s) are down: Cisco Serviceability Reporter.Also all of our registered gateways and Media devices were aff...
redrobish by Level 1
  • 458 Views
  • 3 replies
Hi,I have a 2851 with 2 VIC2-2BRI-NT/TE. I configured trunk groups to rollover between the 4 voice ports for outbound calls. Everything works fine with all the ports connected (I can place and receive many calls at the same time). Then I disconnec...
mleboeuf by Level 1
  • 1473 Views
  • 17 replies
So, this method doesn't work on the older firmware. i tried and doesn't respond.http://cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a00800941bb.shtmlhow can i get these set to factory default?no CM setup locally.i do have 2821 rou...
beddo by Level 1
  • 1573 Views
  • 4 replies
