IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5801 Views
  • 14 replies
I have just upgraded my cisco ios to 12.4(15T) but my cme-gui files are still on the router's flash. If I just extract the new cme-gui tar files into flash will it automatically overwrite the old gui files or should i take another approach, such as ...
I'm planning an upgrade from CM 4.1 to 6.0. I've been reading thru the Upgrade Guides, etc. but I'd like to know what other things I should do before the upgrade. This is a very drastic upgrade as the Upgrade guide indicates "your hard drive will b...
gflorescu by Level 1
  • 714 Views
  • 10 replies
I have a customer who has a small NOC, 8-10 users. Today they have a Nortel PBX and use MCR keys to answer calls(same number on all phones. Call comes in and is answered, next call rings all idle phones.) They have Symposium call center today and ...
lbrenne by Level 1
  • 319 Views
  • 2 replies
Hello, I am trying to figure out how the voice mail codes actually work in CM 4.2. I have a code set to turn MWI on and a code to turn it off. How do these work? If I dial the codes from my phone it turns MWI on or off (depending on the code used). W...
alatamore by Level 1
  • 378 Views
  • 1 replies
Hi,our ccm cluster has dedicated tftp, publisher. If I have to install the devicepack to ugprade the firmware, which server should I install? i am assuming that's the tftp server only, right? Thanks
