IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5679 Views
  • 14 replies
Is there a good QoS monitoring tool for monitoring voice quality issues other than Wireshark? We have a centralized CUCM 11.x cluster with over 100 remote sites connected either through MPLS or dmvpn. Those remote sites use centralized SIP trunk for ...
Hi,  Can I create just one CSR request via CUCM Publisher OS GUI using the subject alternate names (SANs) adding other two clusters with 6 nodes each + unity connection clusters ? Just trying to understand if I can do that, I can have only one CSR ...
Vg224 status unknow on cucm this gateway contains ports for fax. >not able to ping to vg224 other vg224 are pingable.Main gateway is h.323 which is working fine How to troubleshoot the VG224 why its not reachable ?
S Sadiq by Level 1
  • 719 Views
  • 4 replies
Unanswered Topics
