IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6061 Views
  • 14 replies
Experts, I need you help in upgrading the Cisco Phones. We are migrating the Cisco phones from CUCM V 7 to V 11. 7911 Model - Old firmware SCCP11.8-3-2S and the new firmware SCCP11.9-4-2SR1-1S 7975 Model - Old firmware SCCP75.8-5-3S and the new fir...
S N by Level 1
  • 1783 Views
  • 1 replies
I'm trying to connect a Code Blue phone model InterAct-501 to the new Cisco Sip ATA 190. These phones are replacing the old elevator analog phones. I have configured the Sip dial rules as follow (see screen shot attached) which allows PLAR. This new ...
Hi, I recently installed a CUCM cluster to use DNS. Now during the installation, I was unable to add the FQDN  which I assume was not an issue. I just added the hostname. However when i began to add phones, they each started getting dns resolution i...
rramlal by Level 1
  • 800 Views
  • 3 replies
I have a 7937 conference unit which I am unable to change to English language. I can view the currently set language (Swedish) however there is no option to select any other languages. I have carried out a factory reset on the unit, upgraded the f...
R MAS by Level 1
  • 1507 Views
  • 15 replies
Hi,Someone has a working config of CME using SIP Phone 3905 and with pickup working?My issue is that pickup doesn't work.When I press the feature button then pickup I get reorder tone.I have configured pickup-group on voice register dn and the servic...
Two DN's are in same partition and with same CSS. 352 DN is unable to call some destinations (fast busy) and 312 DN calls with no problems. Phone change had no luck. When I change DN from 352 to 351 all works fine. 352 DN was created some time before...
Hello, I want to configure call pick as below. Phone A needs to pick up phone B calls But Phone B is not allowed to  pickup the Phone A calls. How do i configure? Thanks Suchi
Suchi by Level 1
  • 177 Views
  • 1 replies
Hello I have a new domain that I need users on it to log into Cisco Jabber. I am running version 10.5 of CUCM, IM & Presence. I have configured all the LDAP settings for the new domain, and the import of users from the new domain is working and I can...
Fergie M by Level 1
  • 2266 Views
  • 9 replies
