IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6169 Views
  • 14 replies
Hi.I would like to get a better understanding of how the built In switch works In an IP phone.  As I understand It:  One port connects to a main switch and Is a trunk port.  There Is an Internal access port that connects the voice vlan to the phone. ...
Reprovoid by Level 1
  • 1736 Views
  • 7 replies
Resolved! B-ACD on CME
OK, not sure why this isn't working.  I have a CME 8.1 system with a B-ACD setup to do basic call queueing.According to the documentation, you're supposed to be able to setup an "out' for the caller to press a key and get out of the queue prior to th...
Kynnzak by Level 1
  • 1080 Views
  • 5 replies
HiWe have a DDI range where a few numbers need to be re-directed to a QSIG trunk using more specific dial peersNow we have the "problem" that on the incoming dial-peer the DDI range is translated to our internal numbering plan.is there a way to exclu...
kpintens by Level 1
  • 515 Views
  • 2 replies
Resolved! Re-direct a call
HiWe have a H323 gateway and we need to re-direct/deflect certain DDI number to a QSIG trunk on the same gateway.In ohter words, certain DDI numbers will go to IP Phones but a few numbers in that range need to go to the legacy PBX via QSIG (or other ...
kpintens by Level 1
  • 381 Views
  • 2 replies
Trying to do some things on CUCM 8.6.2a with CIUS tablets.  Can't find documentation on how to do the following things:1.  While on a video call, how to you get the CIUS tablet to switch over and use the REAR camera on the call (i.e. how to switch be...
