Call Forwarding via XML
I have new CUCM 8.5 installation and want to present notification of a call and its CLI to an XML server. Can anyone assist me with this?
Hi all, I am now using the CUCM 8.5, and trying to send the CDR record to the billing application (CM8.5 > FTP)But it seems not working, seems the CDR record cannot send to the FTP ...Here are the things I have checked:In Cisco Unified Serviceability...
I'm running into a problem with VoIP phones not working properly when the port they are connected to is configured with "ip verify source port-security". It appears the phone boots and gets an IP address, but beyond that it just hangs. I do not have ...
Hi,I have a 2811 router with 2 E1 Pri and connected to a 4.1 CCM.My understanding is that the link between CCM and the PRI is direct through the binding belowinterface Serial0/0/0:15 no ip address encapsulation hdlc isdn switch-type primary-net5 isdn...
Actually I have this architecture:- Cucm 7.0.2- Presence 7.0.3- Unity Connection 2.1.0I'm going to upgrade the Cucm to 8.5 version.What about presence and unity connection?I have to upgrade also this 2 server?Thanks
HelloI have one 7911G-V08 phone where its coming "CP-7911G Diagnostics(v10.02.00.14) on the display at the top and in bottom its coming Cisco System where all the other phones in the network is working fine. I tried to do the default factory settings...
Hi,A company has 2 offices one at San Jose and the other at Shelton (Single CUCM cluster). I have Mobile voice access implemented.San jose MVA number is x and Shelton MVA number is y.Now, if a Shelton user is at his home location, he uses Shelton MVA...
hi all,i am having uc 560 with latest software pack 8.2.0 . but whne i amtrying to attach console in 7945 i am not able to attach it in the ephone option i am not getting addon option for 7945 type.is it bug or is it limitation.help me in this issuet...
I want to block ALL incoming calls to a certain DN but I need to allow just one number to be able to reach that DN.So to block all incoming calls I just put the DN in a different PT so that the Gateway CSS cannot reach it. Now can anyone try to expla...
Dear All,How can I register Cisco IP Communicator as a sip phone into call manager express?I cannot change Protocol from SCCP to SIP in CIPC??Hamed
Is there a workaround to make ATA187 work in Cisco Call Mgr. 4.1 environment?
I have a VGD3 with a T3 that connects to our provider. I need to make one of the T1s on it an network connection to another router. The interface is up but the protocol is down.Is there a command to enable IP processing on the router or interface?Run...
HiI wanted to know if anyone has seen this error before, I only have this problem when i create an extension for a new user.Any help that you could give would be greatly appreciated and thanks in advance and have a great day.
Hello guysSomebody has configured Cisco voice gateway with R2-DIGITAL and MXOne Astra? I'm not receiving the ack when I sent my digits.ThanksPeterson
hi everyoneactually i have a problem with my Cisco AS5300in my network, users call my AS5300 via E1 connection and aftre the call the dial some numbers (phone number ext.), actually its work fine for all telephone provider but only from one provider ...
Subject | Author | Posted |
02-06-2023 12:21 PM | ||
02-06-2023 10:54 AM | ||
02-06-2023 02:33 AM | ||
02-01-2023 09:39 PM | ||
01-25-2023 05:07 AM |
User | Count |
10 | |
5 | |
4 | |
4 | |
2 |
