IP Telephony and Phones
Personalize banner_3
Labels
According to the document at http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps9900/data_sheet_c78-504890.html the 7925 handset supports WPA2. But I can't see anything on the device for configuring WPA2 (only WEP, et al)  How d...
hi,What is the best way to keep media resouces in media resource list.I want hardware conference bridge to be used only for G.729 calls, for all other conference calls G.711 i want to use software conference bridge. How to accomplish this?
SJ SJ by Level 3
  • 955 Views
  • 5 replies
Dear NetPro gurus,My customer currently has a CME using FXO to connect to a MoH Live Feed on a CD Player.  They would like to migrate this to a Centralized CMBE with the remote site changing to SRST Voice Gateways.  My customer now has the following ...
huntl by Community Member
  • 636 Views
  • 1 replies
Hi, AllI hace some services Down, on my CM Subscriber, this are the services.Cisco DRF LocalCisco DRF MasterCisco Certificate Expiry MonitorI know this, because I have the Real Time Monitoring Tool, but I can nt be able to start by web browser becaus...
Hi All, I am implementing  CUCM for Publisher and Subscriber node. On the Dynamic Confuguration, I have 2 qty of UCM-7816-80 (which is suppose to take care of the two (Pub and Sub) nodes. But after loading the license, on the license unit report page...
We recently purchased 2 Cisco 9951 phones to test with since they are now supported in CME 8.5. The phones work great and every configuration change I've made so far works just fine.However I'm having a strange problem during conference calls. We are...
Hi,using a ISR1861 with his factory ISE.IOS 15.0(1)M3 / CME 7.1Unity Express on ISE 7.0.5Is it possible to personalyse a voicemail prompt with a message and play the voicemail prompt but without giving to the caller the opotunity to record a message ...
danjor by Level 2
  • 2458 Views
  • 11 replies
Resolved! CDR Enabled Flag ?
Hi All,Assume that I have one Publisher and 4 Supscriber in the Cluster. Is is enough to enable "CDR Enabled Flag" just on publisher. All the subscribers have registered phones. if ı enabled "CDR Enabled Flag" on publisher. is it enough or I have to ...
Hi, i'm running Callmanager Business Edition version 7.1.3.30000-1. I need that calls forwarded to one phone extension (without voicemail) can be later forwarded to another extension with malibox in the same phone.I need  to do that because in this v...
