IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6535 Views
  • 14 replies
I have QRT setup and working but whenthe softkey is used not all the options are visible on the phone.For example these are missing when connected:Low volume, The remote end experiences low volume, I can't hear the remote end, The remote end can't he...
HI all,Got a questions regarding the codec. I got two sites:Site A, CUCM 7.1 and one 2911 as H323 gateway.Site B, CME on 2811.Site B has recently joined the CUCM as a site. the CUCM is using CME as h323 gateway, inter site calling working fine using ...
Resolved! Number Restricted
hello  everyoneHow to set up a few branches when  connecting to other internal extensions do not appear on the screen of  the number receiving the call?Can I put  limited number or another number for anyone to call backany help will be appreciated
I have a 2811 VGW registered to CUCM 7.02, is it an H.323 gateway.  Local PSTN is coming in on a PRI circuit connected to the VIC-2TMFT-T1/E1.  One of the inbound numbers on that PRI is a fax number (5551236789) that I need to port out of the FXS car...
