IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5631 Views
  • 14 replies
I am forwarding calls that are unanswered from one ext to another which is working fine. The forwarded calls are not going to voicemail on the destination extension. Does an "Alternate Extension" else need to be configured in the SA Web portion to al...
Hi,I've changed the IP Address of the Unity Connection Server but it seems the IP Address on the Connection Location page does not change. Does this matter? I am trying to network two Unity Connection servers with the same hostname but in different d...
j.dewiele by Level 1
  • 269 Views
  • 1 replies
We are deploying presence in a UCM 7.0(2) cluster. We have UCM integrated with Microsoft AD (both synchronization and authentication). The only problem were having after completing all integration steps is the voicemail piece to unity connection. ...
Hi I have CUCM BE 6.1. 2 days back I rebooted the server couple of times for resolving CUP connectivity issues. After doing this I ran into a problem. All the devices (Phones and Gateway end points) status is unknown while they are functioning fine. ...
shrutid22 by Level 1
  • 2815 Views
  • 6 replies
