Can someone please point me to where I can download the Cisco 7920 Configuration Utility as well as the Cisco 7920 USB Driver? I've looked all over cisco.com and I'm not finding it anywhere. Thank you for any help!
With the help of the following two pages, i tried to create a couple of voice translation rules:https://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/61083-voice-transla-rules.htmlhttps://community.cisco.com/t5/collaboration-voice-...
CUC 11.5 user VM boxes going inactive.. We had to activate all users.These are all local accounts, we have not integrated with LDAP or through AXL.What could be the issue??
Hello, Is it possible to CFNA to a cell phone and then, if not answered there, have the call directed to the original DN voice-mail? This seems to work with internal DNs but I assume call control is handed over to the cell phone when forwarded. Tryin...
We have CUCM cluster integrated with Zoom Call Recording. Spanless recording with a SIP trunk is used. If a call comes in and SNR routes the call to a cellular phone, can the call be recorded?
In the process of converting our remote sites from using analog phone lines for voice service to a centralized SIP solution at corporate (also where CUCM cluster resides). One issue that has come up after the conversion is when a remote site place an...
Hello,Is it possible to check call routing for Extension Mobility profiles logged into IP phones using Dialed Number Analyzer in CUCM?The version I want to test is 8.6 but the question applies to all releases.I have wondered about this for a while bu...
Hi,before days, I had a strange issue at group of phones Cisco 7821 sip phones, this group is under device pool, as I have many branches are registering to one CUCM 11.5 cluster, each branch has its own device pool, the problem was the phones of one ...
We will begin testing Jabber with VDI on Wyse thin clients. Unfortunately the only release (12.1) does not support Expressway. TAC mentioned that there may not be more Jabber VDI releases for this product. Is anyone currently using this product?Or at...
It is normally set in voice vlan 1, but not in such as vlan 10 or vlan 20 Help me Switch Switch#show runBuilding configuration... Current configuration : 1350 bytes!version 12.2no service timestamps log datetime msecno service timestamps debug date...
After installing new cluster, i get the message below after a reboot. Probing EDD (edd=off to disable)... ok Any ideas?
By default Cisco voip phones are conditionally trusted for DSCP and set priority to 5. Also by default any routers wont change this internally and by default switches are transparent. If I enable the switch for COS etc and enable trust on phone inter...
Hello,This issue just started happening last week. In our office when one of our employees receives on a call on their extension, say extension A, a separate user, on extension B is also receiving the same call. I have checked in CUCM and each users ...
We have 3 guys that handle the helpdesk calls. When a call comes in, it rings a hunt group number. The 3 guys desk phones are in the hunt group. With RDP, there cell phones also ring.What I noticed is that if someone presses ignore call on the cell ...
Subject | Author | Posted |
05-16-2025 12:03 AM | ||
05-12-2025 12:06 PM | ||
05-12-2025 06:55 AM | ||
05-11-2025 04:59 AM | ||
05-05-2025 11:16 AM |
User | Count |
5 | |
4 | |
2 | |
1 | |
1 |
