IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6130 Views
  • 14 replies
Hi,How can I change the default "Cisco" Logo which comes in the background image of the 7912, 7941 and 7960 phones??..Tried searching in the Cisco website, I could find only information about logo while the phone is idle, but I wanted to change the l...
rv_viji by Level 1
  • 464 Views
  • 3 replies
I have a PRI with a small telco. When turning up, I had to change the Calling and Called number plan on the CCM gateway config from Cisco CallManager to ISND in order for outbound calls to work. (this is an MGCP gateway).When the phones go into fal...
I have a CME 4.1 with 80 phones, suddenly some telephones are not registering and all the others yes.In the display appears configuring IP, but it never registers.Attached is my config Why could be it? How Can I debug it? It's very extrange because I...
Hi,Our customer get an issue the new feature on CCM 4.2(3) with Group Pickup audio notification. It works fine as well, but if a phone get a notification while being in a phone call, the user hears a sound which disturb him. Sound notification is a g...
Hi,I have a cisco call manager and 8 IP phones all were running smoothly,all of a sudden the 8 IP phones are not getting registerd with the Cisco Call Manager.I am not able to fix the problem.Can any one help me to resolve the issue.It is very critic...
Lavanholy by Level 1
  • 294 Views
  • 2 replies
We are looking to setup home offices that can have only 1 Ip Phone. We already have ASA5505 at site A they would work fine connecting back to the ASA5505 at site B but we are looking for the same sort of device but cheaper. As it will coonect to the ...
redrobish by Level 1
  • 303 Views
  • 2 replies
For my inbound gateways I have 4 as the significant digits. For my PSAP call back do I need to change the route point from 913XXXXXXXXXX to 913XXXX or should I leave it as default? And do I need to shorten my ELINS to 4 digits as well?Thanks
jfn by Level 1
  • 873 Views
  • 3 replies
1.Do we need to program IPCC or CUE scripts during lab?2.Looking how to access Translation rules documents from UniverCD, not able to do so.3. Do we need to change phone load for ATA for example from SCCP to H323 and viceversa?Answers will be rated.T...
