Resolved! cucm_instantmessaging_lync_jabber
hi all, can we use instant message from lync federated with cucm and acess via cisco jabber client, any reference doc please refer? regards balaji
Hi Guys, Does any know what the list of the process types is on CUCM. EG in this PID PID=SIPD(2,100,74,61) The format of the PID= Process name (Node_id, Application ID, Process Type, Process Instance) The 2 =node ID 100=CUCM 74= I believe is the s...
Hi, Is it possible to run CUBE on a CSR1000V to support SIP trunks where the CUBE only has a single interface? (plus its sat behind my Broadband router which isnt very flexible - would I need to use Port Forwarding if NAT isnt supported by SIP Provi...
Greetings,We recently deployed 8945 video phones. I've noticed when pressing softkeys DND or Hlog (log in/out of a hunt group), there is a brief notification to indicate the action is enabled, however will disappear after a short period. On our previ...
Dear All, Can we use SIP in India for both inbound & outbound? I heard that is not fully utilized and some TRAI regulations, is that true? May you help me with reference link, please?
Hi, I hava a CME 7.0 setup with VIC2-4FXO card, I am using b-acd ivr for incoming calls, First issue is whenever anyone dials in from PSTN and just disconnect after the call connected to ivr.. the call doesn't disconnected but the FXO port remains of...
Hello, On a UC520 with Version 7.1 Cisco Unified Communications Manager Express we have configured the following hunt group: voice hunt-group 70 parallel final 314 list 313,321,331,341,351,371,303,301 pilot 7777 The voice port configuration: voice-p...
As we're adding DX, SX & MX units to our system, we're adding more of these larger firmware images to our system. The latest new model we've added to our system has resulted in us hitting the high water mark on logging every five minutes. (I don't ha...
In my environment I have call manager 10.x with green number it will forward only call toward user, but not receiving. is it possible? might with css and partition?
Dear All, I have 160 voice mailbox licenses, and all the licenses have been occupied. But some of the users do not use it at all. I would like to figure out those users and remove voice mail for them. How do I find when was he/she last used voice mai...
What is gained by adding advanced IOS services to a VG204XM?
Just got these phones and tried to use an existing template, but could only find one that had max 30 speed dials. I would like to use all of the buttons as speed dials on the expansion module. Thank you.
Hello, Is there any way to see a specific day for call history in gateway? I've been using How many calls does gateway save (or time period)? How can I see calls going through a concrete voice port (FXO or FXS)? Version of my gateway: 12.4(9)T7, ...
I am working with a group with a large helpdesk for which we have defined "custom access control groups" and "roles" within user management. That been said many Help Desk Staff continue to use the "Modify Button Item" for Add/Change/Delete lines on ...
We are having issues with Cisco ATA 187, that suddenly unregister from our CUCM, and come back again after power cycling them. All of them are registered trough our CUCM Cluster running 8.5. The devices have 9-2-3, and I saw that there is a Special V...
Subject | Author | Posted |
05-12-2025 12:06 PM | ||
05-12-2025 06:55 AM | ||
05-11-2025 04:59 AM | ||
05-05-2025 11:16 AM | ||
04-30-2025 05:24 AM |
User | Count |
5 | |
3 | |
1 | |
1 | |
1 |
