IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5842 Views
  • 14 replies
Hello Cisco expertise, i'm starting to configure one of my Voice Gateway for a public SIP trunk. My provider give me the SIP ip address and RTP ip address, but I don't know how to configure RTP ip address on my Voice Gateway. I'm able to do outgoing ...
CUCM VERSION 8.5.1   GOAL: UPGRADE FIRMWARE FOR 8831 CONF PHONE. Hello, I've just uploaded successfully the cmterm-8831-sip.10-3-1-16.cop.sgn cop file.  Now when I goto OS ADMIN GUI to upload the load I get "Name does not match any filter pattern". ...
Hello all   I'm configuring a VG202 using the MGCP protocol. However, I get no ringback tone when I call to pstn. where I mistake please suggest me.see config below. Show run Building configuration... Current configuration : 1612 bytes!! Last config...
RTMT is porting the following from my Publisher and both Subscribers. At Wed May 28 15:10:11 BST 2014 on node 10.211.7.100; the following SyslogSeverityMatchFound events generated:  SeverityMatch : Critical MatchedEvent : May 28 15:10:04 dbs-cm-donpu...
I am currently having a problem where DTMF relay is not working correctly from a new SIP ITSP. My topology is ISTP<-->CUBE<-->CUCM. I was not involved in the inital planning session with the carrier however I am of course assuming that they are suppo...
