IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6055 Views
  • 14 replies
Is citrix supported/work with IP Communicator for teleworker scenerio? alot of our teleworkers VPN in fine with ipc. we are trying to get away from giving vpn access to everyone, and would like to use a citrix solution. I believe i was told in 2008 i...
I can't seem to do it across the VPN. Everyone is default g.711Internal it works fine.The site across the vpn can not do conferencing. So it seems that something is off. I just can't put my finger on it.I have the CFB confgiure and have the MRG in bo...
Hi all,We're deploying IP Communicator alongside a 3rd party SSL VPN which advises it supports Cisco IP Communicator 1.x+ using IP pool allocations. However, I've not managed to get it to work unless I specify the IP address for network audio manuall...
Hi,can soneone please help, I have our remote sites registered to the the Call Manager Cluster with SRST in place if failure on the main WAN path. However a couple of times now on a main WAN failure the telephones have correctly registered to the SRS...
The problem is I dial my voicemail pilot number, the call is picked up but I don't get any audio output from Unity. I would expect the usual 'Please enter your PIN' etc…I am running:Cisco Unified CM Administration (7.0.2.20000-5)Cisco Unity Express...
mmoulson1 by Level 4
  • 585 Views
  • 1 replies
