I believe I need to implement a TCL script that will detect the Cisco VOIP line being hung up and then send the # sign through the FXS port. Can anyone point me in the right direction?ThanksMike
Any idea if the Cisco 37XX can be configured as below with different protocol on each ds0 channel? ThanksFor example...controller E1 1/0 framing NO-CRC4 clock source internal ds0-group 0 timeslots 1 type e&m-melcas-immed ds0-group 1 timeslots 2 type ...
Hello,I have this issue with anyone calling out to some numbers the Cisco handset (calling) will not ring however the called person (called) does hear the ringing. The call does connect if the remote (calling) person pickup. Now this is random and it...
Hi there teamCan someone shed any light on the following error I get when uploading a new MOH wav fie:Unknown CM_Media_PayloadType 260File uploaded OK but get this message in the MOH audio file screen.Any ideas welcome
database replication seems broken, reporting replicate_state 3 on both pub and sub (only 1 of each in my setup) from the unified CM database status. Tried restarts of pub and sub to no avail. Also tried utils dbrplication repair on the pub this fa...
Hi, I am going to add a new MOH wav file to our CUCM but have only done this on the windows 4.1. I am assuming that I can just browse to a shared drive where the file is stored and download it?ThanksSimon
Hi,Does anyone know how long the ATA186 is likely to remain on sale given the launch of the new VG202 and VG204?There is no end of sale notice yet published but given how old they are and the lack of support for fax relay I could see them being remov...
Hi all,I wanna share a c549 between transcoding and voice termination.I know that 1 DSP can handle 4 simultaneous medium complexity calls (e.g. G.711 or G.729a codec) or 2 simultaneous high complexity calls (e.g. G729 or G729b) or 4 transcoding sessi...
I tried searching for a thread on this, but couldn't come up with the right combination of search topics...I had two phones (a 7971 & 7975) yesterday morning that showed as registered in Communications Manager 4.1(3)sr5d, however, they had no soft-ke...
Hi All, we are using CUCM 7.0. in receptionist phone, there are three line buttons, in second and third buttons, the call forward all option is gray out. I need to enable call forward all for line 2 and 3 as well. any suggestion would be very appreci...
Hi I have a pvdm2-64 card installed in my 2851 router it has one vwic2-1mft-e1/t1 card which i am using for voice as a E1 link.I have configured a hardware conferencing bridge with max session of 4 and max transcoding session of 2.Plz let me know wi...
We use CCM 6.1.1 I have a Executive who does not want his phone to ever ring but go straight to his admin assistant and then to another number before going to his voice mail.Here is the call flow.8002 - 8001 - 8003How is this done without ringing his...
I have a cisco 2811 router connected to an Avaya PBX. The cisco gateway is an MGCP gateway in Call Manager 5.1. I recently upgraded the router IOS from 12.4(15)T to 12.4(24)T. After the upgrade only half of the channels on the T1 would come up. The D...
Hi , I have CUCM Version 6.1(3) and i can;t find a way to dialing 0 from any phone and it's will be routed to the reception extn. Any ideas ? Thanks
I was told I could use audacity to create custom ring tones. Has anyone done this? If so is there a tutorial our there? Alternatively is there a source for ready made ringtones?Thanks.Jim Lozano
| Subject | Author | Posted |
| 01-16-2026 03:24 AM | ||
| 12-31-2025 01:52 PM | ||
| 12-10-2025 11:24 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM |
