IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6078 Views
  • 14 replies
I am using perfmon and use system monitor to realtime track number of parameter of all servers in my cluster from publisher.I have issue where I am not able to see any info of sub01 but can see all info from sub02,it says cannot connect to server alt...
Hi, When I transfer a call in CUCM6.1 to another party the call is dropped if unanswered anywhere between 6-10 seconds. I'm assuming that this isnt a timer issue due to the variance in times experienced. I've tried the various associated service par...
dual_line by Level 1
  • 561 Views
  • 5 replies
Hi,I want to make VoIP calls between my Cisco Call Manager sited in Dublin and an NEC PBX sited in New York. In order to integrate them I am considering placing a Voice Gateway in New York and running a MGCP session over my WAN. The Round trip time...
We are on CM 4.1(3)sr7 with our voice on PRI and are still using PSTN for faxing. I am looking for someone who has ATA's working in a similar environment. Can you tell me what model you are using or recommend the model best for our version and purpos...
Hello,I have installed CCM 6.1 and configured some 7911. I configured EM and users can log/logout fine to those devices.then tried to put in work some 7936, the problem is I can't use EM with these device. I configured user profiles and logout profil...
