IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6067 Views
  • 14 replies
I have problem with CCM 4.2 and message:"Warning! Search too general; results truncated""Greater than 500 records matched, but only the first 500 will be displayed.""Please refine your search."Is it possible to change CCM config to show all matched r...
goranr by Level 1
  • 375 Views
  • 5 replies
Dear All,I have Call Manager 4.1(3) on MCS 7825H platform. The subscriber server's HDD gone bad few days back. Upon inspection I found bad sectors. I have got the new disk now. Is it possible to make the Ghost of the old disk and dump it on the new o...
I need to integrate Alcatel 4400 PBX with cme 4.1/4.3. Is this possible we can integrate it.I have done it on CUCM 6.0 with MGCP gateway on QSIG. Can I still use QSIG with cme to integrate the PBX or the other way.Thanks.
sfurqanli by Level 1
  • 391 Views
  • 1 replies
Hi, I am new to voice and would like to check with regards to this module, PVDM2-64. From the product documentation page at,http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd8016e845_ps3115_Products_Data_Sheet.htmlit...
InternetB by Level 1
  • 290 Views
  • 2 replies
Hi NetproI am using the DMA tool for an upgrade of CCM 4.2 (3) to CUCM 6.1 (2), the database is 300 users and the tar file created weighs 12M.In the process, DMA not generate any error or warning, but I doubt generates weight file. 12MB is an appropr...
I need to setup a low cost Cisco SIP voice gateway to use as a test platform for Microsoft Unified Communication Server. This box does not need to support SCCP phones. Can I do this with an 800 series router with an FXO card and voice enabled IOS i...
tato386 by Level 6
  • 478 Views
  • 2 replies
Guysi have currently an MCS-7825 running ccm 4.0. we are in the process of an upgrade with a MCS-7835-H2. i need to put the CCM 4.0 onto this new server. i have the CCM 4.0 software however, it wouldnt detect the new server. what do i need to downloa...
a.gooding by Level 5
  • 319 Views
  • 3 replies
I am trying to do a DMA backup, but it fails due to CDR. I do not need CDR, I tried disabling the services and from the service parameters but DMA still fails...I am not able to do a CDR export from the CAR tool...I tried purging all records from the...
joel by Level 1
  • 365 Views
  • 3 replies
All,I have a CME site in mexico that has a generic dial-peer set up to route 9T calls out the telco line.What is the best way to set this up?How do you place a call outbound from this site, non-VoIP call?I do not know how to dial the US from a Mexico...
I have some users that are using Vista and the CiscoTSP.exe file that they use does not seem to work properly on the new Vista machines? 1- Is there a newer version of this file?2- Do I have to upgrade the CCM version to get the updated version?Runn...
smolz by Level 4
  • 265 Views
  • 2 replies
I have one of our customer running CME with PRI everything works fine, now they are getting a SIP trunk from Verizon through MPLS. I never done SIP trunking so I need some help in dial-peers for outbound and inbound ..here is the info I got from VznS...
balukr by Level 2
  • 469 Views
  • 1 replies
I have a technical question that i believe you can help me with.We have a factory test for our VoiP system (using cisco call manager). In the scope we have to show that no more than 2 in 10,000 locally originating and incoming calls misdirect, unsucc...
