IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5760 Views
  • 14 replies
I can not get CUCM to play the ringback.wav file for MOH. This file was downloaded from UCCX (g711 version). All other MOH files work fine. There were no errors while uploading the file to CUCM, the MRGs and MRLs are configured correctly, the phones ...
I have a call manager 5.1 and I need to do the upgraded but I have doubts about two version cisco-ipt-k9-patch5.1.3.2000-3.tar.gz.sgn andcisco-ipt-k9-patch5.1.3.3000-5.tar.gz.sgn what is the different between both?.The reason of this upgraded is why ...
Hi All, I want to take backup of CCM /CDR in Call Manager version 6.0.I have logged into Disaster Recovery option in OS Administration & downloaded SFTP software.But I am unable to take backup.everytime message comes unable to contact SFTP server.Can...
amansoi_5 by Level 1
  • 349 Views
  • 4 replies
I have a Call Manager 4.1 Server Pub and Sub. Its now in a lab environment with the old production configuration in it. Is it possible to wipe the CCM clean and start over? Or do you have to re-install the Application ? I want to delete all the recor...
andrewb by Level 1
  • 352 Views
  • 2 replies
we are using unity 4.2 with call manager 4.2 integration has been done but as soon as we make a call to a subscribers phone I hear a silence instead of any greeting message I have tried several times and checked each option but not able to get whats...
Hi,We have implemented Extension mobility and client requires following features,- While logging out from EM, it should not display username.- Force system to logout IDLE connections after 3 hrs.We would like know how to implement these features. ->T...
