IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6064 Views
  • 14 replies
I'm upgrading my CME to 4.2 version and the process is 99%, is it normal ?for me not !CCME-EP-AUSTRALIA#sh proc cpu sortedCPU utilization for five seconds: 99%/0%; one minute: 99%; five minutes: 93% PID Runtime(ms) Invoked uSecs 5Sec 1Min ...
ogor by Level 1
  • 294 Views
  • 1 replies
Hi Guys, I have the following doubt:When I work G.729 for call external its use 24K for call, When I work G.711 for call locally its use 80K for call. Ask, If I will have 03 sites for example(Sao Paulo, Rio de Janeiro, Minas Gerais), if I work in Sao...
We have Emergency responder version 1.2(3a) sr2a and I need to import a switchport details file. When I am exporting the switchport details file I don't see anything in the location column.For the other column everything is OK. Do I have to rewrite a...
Hello I have a problem integrating the CUCM 6 with an Active Directory. I configure all the parameters of the LDAP system and the LDAP directory, click in the sync button, and the system tell me that the proccess is succesfull. I have end users that ...
I have 2x 1Mbps PPP links from my core router (3660 running OSPF) to one branch (02x 1841) that need to be balanced. My concern is about the load at the branch's routers (02x 1841), if I enable OSPF, considering that we don't summarize routes and my ...
Hello,Voice termination applies to a call that has two call legs, one leg on a time-division multiplexing (TDM)interface and the second leg on a Voice over IP (VoIP) connection. This termination function isperformed by digital signal processor (DSP) ...
goranr by Level 1
  • 1384 Views
  • 4 replies
Hi all.We have two CCM (1 publisher and 1 subscriber).Now all phones register on publisher.We want to make some "load balancing" and register some phones on subscriber.We have made a new VLAN, a new dhcp scope, and in this scope we have configured su...
Hi,i have a GSM adapter plugged into a fxs port.If i place a call from a IP phone everything works fine. If i put on hook the ip phone and try to place another call i get a busy tone and the only way is to unplugs and plugs again the cable that conne...
