IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6100 Views
  • 14 replies
Hello,I have a 2851 GW, integrated with CCM 6.0we have a few fax machines attached to ATAs and the main fax number attached to an FXS port on the GW. however most of the times when somebody sends a fax, the fax receipt is truncated and it happens ran...
We have installed Extension Mobility on out 7940 & 7912 Phones. Whave created the Device and Device user profiles.The good part is Extension Mobility is working and the user is able to log in , call as per the profile that he is supposed to do and th...
gsriraman by Level 1
  • 284 Views
  • 3 replies
One of our customer has CM 3.3.3 and they want to upgrade to 4.1.3 and move to different server. So I installed 3.3.3 on new server did a database restore and upgrade to 4.1.3 all went fine till I try to install SQL SP4.I get an error message"This S...
balukr by Level 2
  • 218 Views
  • 2 replies
Hi,i was wondering if cisco 7911 phone could work on an Asterisk PBX (SIP mode)??In Cisco Site the firmware for the 7911 to support SIP is used for upper versions of CCM 5.X, but there is no mention if the firmwares proposed are used to work with Ast...
I have implemented a work around for paging over the phones. Basically, in strategic locations I have set up phones with a new DN set to auto answer.It has been brought to my attention that people are abusing this and using it to evesdrop. Is there...
